What happened:
(1) Had a WD Caviar SE 40 GB that was originally whisper quiet but recently started making constant high pitched noises.
(2) RMA'd the drive and got replacement refurb from WD. It has the same problem! Just not as loud.
(3) Am currently running off an almost 5 yr old Maxtor DiamondMax 40+, which is quieter than the WD! :|
What hard drive should I get to replace the WD Caviar SE? My requirements are: (1) Quiet - I value this more than raw speed (2) 7200 RPM - I need good, but not top performance (3) Parallel ATA100 or better. (4) in the $50-60 range.
I have done a search, and the two manufacturers that are recommended in threads for quiet drives are Seagate and Samsung.
Samsung P80
Seagate ST3800
I've heard the Seagates are more consistently quiet than the Samsungs. Any comments or additional recommendations? I
Samsung P80
Seagate ST3800
