Recommend me a Pressure Washer....
Nov 8, 2012
20,842
4,785
So I feel like I have a lot more maintenance on my new home - and one of the things I've been wanting to get is a pressure washer.
Anyone have any recommendations? I've tried looking around and finding the "ace" product of best bang for your buck but was coming up a bit empty.
Only thing I want is to make sure it works well, not overly expensive, and I also prefer if it comes with one of these surface cleaners... Hollllly crap if you're doing your entire concrete this thing is a gamechanger.
herm0016
8,524
1,132
i would probably go for the harbor freight. the predator engines are good Honda clones. use non-ethonl gas and make sure you drain it after use, dont let it freeze.
Nov 8, 2012
20,842
4,785
How the hell do you get non-ethanol gas easily?
And yeah - I learned from an edger I had that you gotta drain after each use heh. From what I understand the issue is that these small engines can't handle the separation that occurs in the gas?
Hans Gruber
2,549
1,375
I have the harbor freight electric pressure washer. No complaints, does the job. If you want power go with either a Honda engine or a Yamaha if you can find one.
herm0016
8,524
1,132
ethonol absorbs water over time. murphy stations usually have it. the issue really is that small engines sit a lot and you are not refreshing the gas often, getting it hot to evaporate any water in the fuel system. i use pre mix in all my 2 stroke stuff, and non-ethonol in all my lawn tractor. no issues so far after they sit for a long period of time.
Nov 8, 2012
20,842
4,785
I despise anything gasoline so I went electric
https://www.homedepot.com/p/RYOBI-2...e-Electric-Pressure-Washer-RY142300/300405751
Things have changed with electric a lot, so it is great and has worked perfectly around my house.
That cleaning attachment, me thinks, is separate. 30 or 70 clams, depending on model.
Yeah.... I'm definitely not shutting out electric by any means. I just want it to cover the basics - clean the side of my house (2 story), the concrete, the ceiling of our deck (Wasp nests / mud daubers), etc.
I also don't want to have to drive to the pump anytime I want to use it, make sure I empty it, etc...
So the question is - can the electrics do those basic tasks on their own? Or do you need something more powerful to use the likes of one of those surface attachments as well?
bbhaag
7,517
3,172
I went with a cheap SunJoe electric a couple of years ago and so far I've been happy with it. It does 99% of the jobs I need it to do and I don't have to mess around with gasoline, oil, noise, weight, ect of a gas powered model. The one thing I don't like about it is the weird size they use for connections other than that it works great.
Anyway, something to think about when you make you final decision.
BoomerD
66,720
15,120
I have last year's Yamaha version of this:
works very well. Now that they have a Honda-powered version....hmm...I LOVE my Honda lawnmower...maybe I could return mine and get one of those........
although...mine came with the driveway/surface cleaner attachment.
bigi
2,490
156
The one I linked - yes, IMHO.
zinfamous
111,997
31,568
It's hard to believe 3000 psi at 2.2 GPM. That's better pressure than my 5 horse honda puts out.
They have gotten much more powerful recently. But I think a lot of those lest several-hundred PSI depend on the nozzle attachments, which are used to boost the rating with expensive "high performance options" or somesuch.
purbeast0
53,765
6,646
My brother and I went halfsies on this one like 5 years ago:
https://www.amazon.com/gp/product/B004MXKUCY/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I think it's fantastic. After the first year he bought one of those discs and it IS game changing. I can do my patio a lot quicker than I used to, but it still takes quite a while to do.
I can post some before/after pics later on.
EDIT:
before:
one pass on top of retaining wall:
before: (notice wall is clean though)
after:
before:
after:
before:
after:
