Recommend me a hassle-free quiet case fan!
Antoneo
3,911
Hey guys,
I think this topic has been beaten to death (maybe not?) but my cursory quick search revealed little and so I dare ask this question.
I need about three or four case fans to be placed in two computers. I am cutting down on noise in each one and I have deemed that the el cheapo no name case fans that came with my Cheiftec (Antec 1080 clones) cases were too loud. What hassle-free (meaning that I don't have to go attaching "tails") fans are there that are readily available and about $10 each? Recommend away!
Thanks in advance,
Antoneo
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,686
In your Antecs, the NMB fans from SVC will work extremely well. Depending on what's in the box, you may only need the 2 exhausts, or add 2 intakes as necessary. Virtually silent. The Panaflos are also excellent fans, particularly when you can't use as many as in the Antecs. They're stronger and noisier, but still quiet in comparison to what you have now...
snowwie
137
I can vouch for NMB
they're really quiet, last a very long time
and their typically pretty cheap too
I have seen a lot of Dell's equipped with NMB fans, their good
panaflos are great too, though typically a bit more expensive
pabst make real quiet fans too, but they are hard to find (and expensive); they're from germany
just save yourself the trouble of getting those vantec stealths
vantec is evil
Antoneo
3,911
Hey guys, thanks for the advice :). Looks like I'll go buy the NMB fans from svc.
I was just about to get these... any reason not to? High failure rate? Overrated?
amcdonald
4,012
I'd recommend the nmb's for a value purchase, but the panaflo's are worth what they cost IMHO.
There's a smoother overall sound to the noise compared to the nmb. But most people won't hear them at all
chocoruacal
1,197
Yes, it has been beaten to death :) The NMBs are nice, but a word of caution...they push VERY LITTLE air. Barely as in...you can hardly feel it with your hand. My suggestion....take whatever 80mm fan you have laying around and 7 volt it. Actually, though I don't like SVC....their "SVC" brand fans are decently quiet and push a lot more air than the NMBs. Worth checking out at a measly 2.50 a piece. My case fans are as follows:
80mm NMB
92mm Antec (7 volted)
120mm Antec (7 volted)
Teh 120mm especially pushes a lot of air, and is quiet enough that I can't hear it outside of my case.
queenzbwai
19
Good choice going with the NMBs. I have several of these and they're great. Blows more hot air than The Enquirer.
