1. What YOUR PC will be used for: Web surfing, office documents, light gaming, music production.
2. What YOUR budget is: Around $1000 max, but the less the better.
3. What country YOU will be buying YOUR parts from: USA
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from: N/A
5. IF YOU have a brand preference: Intel cpu, nvidia gpu
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are: for now my current videocard. GT 740 2gb.
7. IF YOU plan on overclocking or run the system at default speeds: default speeds, with the ability to overcook though I don't think I will do any OCing.
8. What resolution, not monitor size, will you be using? 1080p
9. WHEN do you plan to build it? By June, but may be earlier.
10. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software? Windows 10 pro oem.
I'd prefer something that will last me 3-5 years. I also prefer a core i7 4.0 ghz. And I want a quiet pc.
