Recommend me a blue led or clear fan to go with the thermaltright xp-120! PLEASE
scheibler4
410
Not sure if you have to have a special connector to run the fan as a cpu fan like a required 3pin or 4pin? Anyways, I would like a clear or blue led fan that is 120mm and can move a fair amount of air to cool my athlon 64 754 3400+. Thanx
scheibler4
410
yea im gonna just get the panaflo and probly a blue cold cathode or somethin. I found the ultra high(u1) panaflo on sale for $11.95...Im just questioning if the xp-120 will fit the chaintech nf3 250. The thermalright website hasn't tested them and I don't think they will
ssvegeta1010
2,192
Id go with a Panaflo and separate Cathode, like you said. Best cooling, and still a little decoration for your case.
pnb263
65
yes... panaflo. I have the 115CFM 120mm fan on my xp120 and it keeps the CPU at 28C idle (38C full load) overclocked from 1800 to 2600...loud, but good
imported_rod
1,788
Evercool and SilenX are both decent brands, and both make illuminated fans. The evercool's move more air than the silenX ones, but the silenX fans are quiet.
RoD
