Recommend me a battery backup
Status
Not open for further replies.
34,175
These power outages got me thinking. I need a battery backup for a medical device.
Label specs:
1.5A
120V AC, 60Hz
80W
Needs to run for ~15 minutes x 4 times per day so an hour/day. Needs to last at least one day. Two or three days use would be better but we'd likely have to leave the affected area if the power was out for much more than a day for other reasons.
Weight/size really not an issue as long as a reasonably healthy adult could move it.
mmntech
17,501
12
A Drilldo is not a medical device.
Seriously though, UPS units are only designed to last for short periods. For frequent outages, it might be wise to invest in a generator or a deep cycle battery system like the kind used for solar setups.
sjwaste
8,757
12
Get an inverter generator if your electronics are sensitive. If not, just get a regular generator. Unfortunately the inverter type tend to be expensive and relatively low wattage, but they'll cover your application.
sdifox
100,508
17,957
An AC motor most likely won't even run on a square wave. It will probably run on a modified sine wave.
Good UPS don't output square wave these days, most are modified sine.
I linked to two, one is modified sine, the other true sine.
actually strike that, they are both true sine, or so they claim.
sjwaste
8,757
12
Can you use a UPS to clean up the output from a generator? Or will the UPS itself get flaky?
sdifox
100,508
17,957
They do clean up the power, they are line interactive. The true sine one does a better job since it does double conversion. So AC to DC then back to AC.
qliveur
4,090
74
Funny, we've been talking about this very subject over at Hot Deals.
You might want to look into CyberPower's PFC line. It's pure sine wave and it's affordable.
Status
