Recommend: Home Water Filter Systems
ECE
92
Hey guys and gals,
Anyone here use a home water filter system? Which ones would you recommend? I'm particuarly looking for one with a carbon block in it for placement under the sink.
Thanks!
Pacfanweb
13,158
59
Not sure of the brand, but my house has a two-stage filter under the house. Has a carbon filter and I guess a regular filter.
Plus, we have a filter at the faucet in the kitchen and for the water dispenser in the refrigerator.
We're on a well, and the filter under the house gets sediment build-up every 3 months or so, so I guess it's well worth having.
Apex
6,511
www.gotapex.com
Have you considered the ones with the built in hot water dispenser? I got one about a year ago (used to have just the room temperature one), and I found it amazingly convenient. I thought we wouldn't use it at all, but it's definitely worth your while.
