Recommend antenna for abit airpace wifi card?
src
434
I bought a PCI-E Airpace card recently (FAR)
Can anyone recommend a range extending antenna to buy for it? I believe it uses an SMA antenna connection
Thank you :)
JackMDS
29,546
422
You have to be more specific about th environment, and where the signal is coming from.
There is different type of Antennae, Range Extending Antenna is a term that does not mean too much.
src
434
I want to pick up my friend's router signal which is a few apartments away
JackMDS
29,546
422
How much away? (in feet) How many wall? Same floor?
Why I ask? because it might be that it can not be done and you are going to waste you money.
Otherwise, http://www.ezlan.net/bridging.html. Look at the end of the page.
