Recommend a wifi router with USB (for external HD)
z28dreams
224
Hi guys,
I currently have a 1.5TB external hard drive that I never use, because I'm constantly on my laptop and don't want to have to drag it around and hook it up. (It requires both power + USB).
Therefore, I'm looking for a solution to hookup the hard drive to the router for constant access.
Any recommendations on a router?
Requirements:
- Must support USB 2.0 (external hard drive interface type)
- Prefer something that is hackable (ddwrt/tomato/etc)
One major question: What is the ideal file system to use? FAT32 just seems ridiculous with the size of various image files these days, but NTFS seems to be a problem if you need to write to the drive.
My main laptop runs windows, so EXT2/3 isn't exactly the most convenient thing.
What filesystem should I go with?
NTFS - which routers would support writing to this?
EXT2/3 - I've seen some routers like the asus that can write to this, but this seems like a huge pain in the ass if I ever need to hook up the USB hard drive to anything other than the router.
What do you think?
z28dreams
224
Adding:
Would also consider a very inexpensive USB->RJ45 style connector to hookup the drive to the switch
JackMDS
29,563
432
Choosing a Wireless Router for its USB port is rather silly. (It is like buying a car because of its Stereo Radio).
No matter what the service provided by these ports is always far bellow what can be provided by a real Network Server Drive.
Any old computer (P-III and above) running Win 2000 (or whatever OS comes with it) can do much more, and better as a Server than these USB port.
The criteria to choose Wireless Router is by the needs of the network's Wireless and the general load of Network traffic.
The Asus above is a good choice for decent price.
Otherwise, http://www.newegg.com/Product/Produc...ear%203700
:cool:
