- Dec 29, 2010
- 3,034
- 1
- 81
I'm looking for a wall-mounted monitor mount for a 24" auxiliary display, that lets me swing the monitor up/down in front of another retractable display shown pushed back against the wall here.
The issue is I want to be able to have the mount support the aux display up above my triple-screen eyefinity setup, flush with the center eyefinity monitor and kind of sitting on top of it (another forum member has a link to his 4-display setup that is just what I'm trying to describe).
Here's the weird part: I want to be able to slide that 24" aux monitor down in front of the center eyefinity monitor, after pushing back the eyefinity monitor flush against the wall. Currently, the center monitor is wall-mounted and I can push it back almost flush against the wall, very easy.
The idea is that for normal computing, I push back the eyefinity display and bring down the 24" aux to use for internet and SC2 as my main display. Then, for FPS games, I pull the 24" aux up out of the way, and bring forward the center eyefinity display.
Here is a picture to show what I'm talking about. The eyefinity displays are 20.1" 1600x1200, and the aux display is 24" 1920x1200. Without a wall mount for the center display, it currently sits on its own stand, so I slide the 24" aux to the side behind the right monitor and pull out the center eyefinity display when I want to do eyefinity. The picture shows the center eyefinity display pushed back against the wall with the 24" aux sitting in the middle in front of the eyefinty display:
