Recommend a power injector
Lifted
I'm looking for power injectors for the following devices. Any recommendations for reliable models that are < $75?
Cisco SPA508G
Cisco AP541N
I don't have any experience with those particular devices, but whenever I've needed to power a one-off PoE device, I've used the PowerDsine 3001 with good results.
Just make sure those devices support IEEE standard PoE. Cisco for a time had proprietary power over ethernet before 802.3af was ratified.
Yeah, these are all newer devices that don't have any Cisco special-non-standard PoE adapters.
Yep, the PowerDsine ones work well.
Depending on how many devices you need to power, though, you might consider a PoE switch.
