Recommend a good case for $100 or less?
imported_Tomato
7,608
I'm working on building a computer right now, and am in the market for a case... can you recommend a good one (450 watts or more, ATX, SATA compatable) for $100 or less (if possible)? 2+ fans a plus, thanks!
Could you recommend the best place online to purchase computer parts, cases, etc.? Thank you!
Nikamichi
7,759
Absolutely go with the Antec Sonata w/380 PSU. It's 99 bucks, so it should definitely fall within your budget. :)
Newegg currently has a special w/free shipping... Link
Gurck
Banned
Mar 16, 2004
12,963
Are you sure you need that much wattage? My case is really awesome, but comes with "only" a quality 350w psu. If you're just looking at a basic rig at stock speeds, it would be plenty.
imported_Tomato
7,608
Originally posted by: JetBlack69
case or PSU? or a case with a PSU?
Either a case with 450 min PSU or with no PSU at all (will buy separately), thanks!
I went to Fry's today and the selection there was disappointing. Newegg or ZipZoomFly, got it... I'll check out those now, do they have the best price/selection online?
FleshLight
6,883
Originally posted by: Tomato
<blockquote>quote:
<hr><i>Originally posted by: <b>JetBlack69</b></i>
case or PSU? or a case with a PSU?<hr></blockquote>
Also check directron.com and svc.com
imported_Tomato
7,608
Some of the cases suggested look great... is 450w too much? It's going to be for gaming (Doom 3, Warcraft, etc.) so I thought more wattage was necessary to support the graphics card (is that true?).
EULA
940
this MAXTOP Signature Series Type II Mid Tower Case is awesome! Its got a 120mm fanhole on the back (which also is machined to fit 80, or 90mm fans) as well as side and top 92mm fans, and an 80mm fan in the front.
This case has excellent airflow, and its made from steal, so it's sturdy. Its probably the best case out there in the $30 range. If I ever build another computer, I would definately get the same case. Maxtop also makes similar cases with PSUs included...
imported_Tomato
7,608
Originally posted by: FleshLight
<blockquote>quote:
<hr><i>Originally posted by: <b>Tomato</b></i>
<blockquote>quote:
I went to Fry's today and the selection there was disappointing. Newegg or ZipZoomFly, got it... I'll check out those now, do they have the best price/selection online?<hr></blockquote>
Will do, thx. Is there a place online that compares prices between all those sites?
FleshLight
6,883
Well if you're getting an x800 or fx6800 then yes you're gonna need that much (two 12v leads). Other than that it's an overkill.
shiner
17,112
Originally posted by: Nikamichi
Absolutely go with the Antec Sonata w/380 PSU. It's 99 bucks, so it should definitely fall within your budget. <img src="i/expressions/face-icon-small-smile.gif" border="0">
Newegg currently has a special w/free shipping... <a target=_blank class=ftalternatingbarlinklarge href="http://www.newegg.com/...w...gt;Link</a>
</a>
Sonata is overrated....get this one
Larger than the Sonata inside and every bit as quiet.
EDIT
Crap...didn't see that you wanted a 450+ PSU. Still the PS in the case above should be more than enough.
Anubis
78,712
427
tbqhwy.com
<blockquote>quote:
Some of the cases suggested look great... is 450w too much? It's going to be for gaming (Doom 3, Warcraft, etc.) so I thought more wattage was necessary to support the graphics card (is that true?).<hr></blockquote>
well if you run 5 HDDs 2 optical drives and fill every PCI slot as well as OC its not overkill
Nebor
29,582
12
Originally posted by: PowerMac4Ever
Man this upgrade is really screwy.. threads in the Cases and Cooling section are now showing up in Off Topic!
But things seem to be back to normal, as no humor has found it's way into your post. :D
Anubis
78,712
427
tbqhwy.com
why does everyone like the sonata so much? its ugly and it has a fusking door in the front, cases with doors are stupid
amdskip
22,530
13
Because it is a flimsy cheap case. Get a case without a power supply and then purchase an Antec power supply.
Anubis
78,712
427
tbqhwy.com
because its a no name brand, the case is metal which means its heavy, its not as big as teh Lian Li or the sonata inside
Schadenfroh
38,416
4
people in college can use the key and lock it down so people can use the dvd rom when they are not there
imported_Tomato
7,608
What makes it flimsy? And what case w/out a power supply would you recommend? Everyone seems to prefer the Sonata...
PowerMac4Ever
Banned
Dec 9, 2000
5,246
Originally posted by: Nebor
<blockquote>quote:
<hr><i>Originally posted by: <b>PowerMac4Ever</b></i>
Man this upgrade is really screwy.. threads in the Cases and Cooling section are now showing up in Off Topic!<hr></blockquote>
But things seem to be back to normal, as no humor has found it's way into your post. <img src="i/expressions/face-icon-small-happy.gif" border="0">
1. I'm Hilarious
2. You're not.
3. You're obviously bitter about the pwnage you received from me in the NSX thread... so bitter that you're trying to undermine my hilarious comments in other threads.
