Looking to listen to blue ray movies on my PC along with gaming.
I cant seem to get regular speakers to work threw a sound card or, HDMI out of my GPU .
I have tried optical out from my sound card and hdmi out from my gpu
You may just need to go to the Realtek sound settings and set "Digital Output" as the default device (for optical output). *Could it be something similar with the Soundblaster? If that doesn't work, the next step I would hit is reinstalling sound drivers.
Are you able to select digital output in Foobar or other player? With 3 sound devices connected, you should be able to select any of them in Foobar.
I have a logitech 2.1 speaker a Very cheap one that works fine threw the SB card. I can not think of any item other item I would need to hook up digital
Sounds to me like you don't have the correct audio output device set. Right click on the speaker icon in your system tray and clock Playback devices. You should see a window with a list of devices. Right click on the one that corresponds to the digital output you're using (HDMI or optical S/PDIF) and choose Set as Default Device.
