recommanded Silent PC parts?
dhkkim
Samwoo 300W POWER SUPPLY / Model: Simple XQ-A (pulled out from 5year-old desktop) - VERY QUITE. (quiter than antec)
I bought 80mm fan from panaflow(?) .. which was louder than one i had previously....... *disappointed*
Samsung harddrive.(model: spinpoint?)
Segate harddrive- Bacurrada V
- Everyone Pleaese recommend the parts which has FAN(i.e cpu, videocard,,etc)
quiet ! its quite bad bad when you can't spell. (/end rant)
seasonic super tornado makes one of the best QUIET power supplys.
Noiseless? ->
Water cooled cpu, gpu, hard drive, northbride. big hose. 50 gallon drum in the ground in your garage with pumps there too! ^^
Seasonic Super Tornado or S12. No contest-- Quietest fan-cooled PSUs available. The only PSUs quieter than Seasonics are fanless models.
Nexus, SilenX and Papst also make slow-speed fans which are known for quietness... You can also put those Panaflos on fan controllers to further cut down their noise.
Those are nice yep, especially the ones with the Nidec motor.
Go Zalman CNPS7000 or 7700 for your CPU heatsink, depending on which can fit your motherboard. Pick up a Zalman VF700 or Arctic Silencer for your video card. And if your motherboard has a northbridge fan, you need to either replace it with a quieter unit or put it on a fan controller.
You also want to visit Silent PC Review and read up on quiet computing there.
HTH.
Uh....noiseless? Silent? Don't think so. I second you visiting SPCR. Anandtech is ia good place for certain things, but not quiet PCs.
