Originally posted by: 0roo0roo
rayovac 15 min all the way. 15 min makes it so you can charge at the last moment. alkalines pollute..only use when totallly necessary.
Ick, no.
If you want your batteries to last 200 charges, maybe.
Fast is NOT good. It overheats the batteries, and you will never reach full capacity in such a short time. Even with the good fast chargers(120 minutes), you need to let them sit with the trickle charge for a while to reach above 90% capacity.
If you read the review on Imaging Resource, you know that the Maha chargers are the best.
The Powerex 2200mAh batteries also come out on top of the list. This is what I have, and I can get around 350-400 pics out of my A60 with a full charge. I always use the slow charge option on my Maha C401-FS to prolong battery life.
If you do not take care of your rechargable batteries, they will not last. One of the most important things is heat. The second most important thing is charging habbits. It is better to let the batteries fully drain before each charge than to stick them on the charger regardless of their level of charge.
There is no point in getting lower capacity when there are 2200's available. Coupled with the Maha charger, it will run you about 55$.. but it is worth it. Just consider it an investment, because you will save much more than that on batteries if you purchase a good charger.
Go ahead and get any batteries you wish, the charger is more important to the longevity and performance of the battery.
Maha C401-FS & Powerex batteries
Powerex discharge chart
