Modelworks
- Feb 22, 2007
- 16,240
- 7
- 76
Charging rates are measured in C/unit of charge. If the battery is a 2000mah then the options for charging rates are:
C/10 = charge at 200mah for 10 hours
C/3.3 = charge a .6Ah for 5 hours
C/1 = charge at 2A for 1.5 hours
Anything less than a 1.5 hour charge time for a cell is destroying the battery. The reason for the 1.5 hour charge time for C/1 is because nimh are only 66% efficient, for every 100 units you put into it, you get 66 back.
A good charger will discharge the battery before charging it. Even better chargers will use pulses to charge where the battery is charged for a second, discharged for 1/10th second then charged for a second, cycle repeats until battery is finished. The 1/10th second discharge cycle lets the battery recoup the hydrogen lost in the charging process.
I tried the retail chargers and most sucked. Batteries charged but never had their stated capacity. I got sick of it and built my own and even the cheaper nimh batteries now have good run times.
