GullyFoyle
A friend of mine uses a 2.6 Ghz Celeron e-machine primarily for htpc. He uses Sage & a couple of Hauppage cards, which run fine on their own. But if he tries adding web browsing on top of that, he experiences performance issues. I think the machine has 768 MB of memory.
He wants to go with a new pre-built machine, and only re-use the tuner cards, and perhaps some HD's from the old machine. And maybe the monitor, I'm not sure about that.
Any current hot deals you can recommend? Is it possible to spend under $600 and still outclass his current machine?
Under $500, even better!
Let's leave the monitor out of the equation for now.
Thanks!
Thanks!
