- Mar 29, 2007
- 6
- 0
- 0
Hi, I am looking for some advice on rebuilding my current computer by replacing the mobo, cpu, and ram, with a new SSD boot drive.
The current PC is 4 years old, takes a while to boot, raid 5 needs to go, too many hard drives. I enjoy building computers, I've built a number of them in the past, but nothing in 4 years. I originally used a SAS mirror for my boot drive, and raid5 data drive, then did an upgrade install from Vista to W7HP, but when I tried going back to a previous restore point it blew up in my face due to the SAS drivers and the upgrade install from Vista. I then made the raid 5 set my boot disk, but it takes several minutes to boot, and the raid5 set is always hiccuping
currently: LIAN LI PC-V1010B, Asus P6T deluxe, core i7 920, 12G corsair XMS3, Noctua cooler, 5 x WD6400AAKS as raid 5, 2 x 136G SAS 10k as raid1, GTX 550 Ti, ASUS Xonar DX 7.1, LG GGW-H20L DVD
new (not purchased yet): Asus Z77 sabertooth, core i7 3770, corsair CMD16GX3M4A1866C9, samsung 840 pro SSD, corsair H80 cooler
What I am thinking is to clone the existing boot drive to the samsung 840 pro SSD, replace the mobo, cpu, and ram, then do an upgrade install to the SSD so it will see the new hardware. I would then use the other disks as several raid1 mirrors for several data drives. I know I would have to move a lot of data out of the way to reduce my boot drive size so I could clone (would like to use the 256G 840 pro rather than paying for the 512). I do have a seagate external backup drive with my data backed up, but I'm hoping to clone so I don't have to reinstall everything. I only have about 600G of data on this 2tb raid 5 set, so I don't really need all those drives. I'm concerned they might start failing before long, and depending on my backups and a new SSD instead of a raid boot disk.
Does this plan seem reasonable? I usually do new installs, but in those cases I have two computers, old and new, rather than a rebuild of the hardware. I'm concerned about cloning, I have not done that before, and hoping that a clone + upgrade install will make it go a lot faster so I'm not without a completely functional computer for a while. I would not care to reinstall all my software if I don't have to.
I'm a Unix sys admin at work, so kind of a computer junkie , I tend to overbuild because I can. A full new build would probably double the cost with a new case, PSU, GTX 660, etc.
Parts to Upgrade: (CPU, mobo, RAM, SSD) CMPSU-750TX
Do you need to buy OS: No - use existing upgrade W7HP from newegg
Preferred Website(s) for Parts: newegg.com
Parts Preferences: Asus Z77 sabertooth, core i7 3770, corsair CMD16GX3M4A1866C9, samsung 840 pro SSD, corsair H80 cooler
Overclocking: Yes
SLI: Maybe
Your Monitor Resolution: 1920x1200
Overclocking: Yes
SLI: Maybe
