Reboot problem
FNP90
160
My computer rebooted all by it's self last week and now it just did it again today. Both times it rebooted I had just gotten done burning DVD's (ND-3520a is my DVD burner). I did burn a few DVD's a few days ago and my system did not reboot. Any ideas on what would cause this? According to SpeedFan my CPU idles 35ºc and when I'm running Roxio burning a DVD my temp reaches 55ºc, is this a normal temp change for this program? I'm running a Zalman 7000B-ALCu CPU Cooler and I run it at max RPM (2400RPM) when I'm doing anything that causes the temp to reach 40ºc. Typing this right now the temp is 38ºc. I used the thermal grease that came with the zalman but, I do have some AS-5 coming and when I put in my new video card in I will put the AS-5 on it.
I upgraded to a new CPU and memory two weeks ago and I have reinstalled windows XP pro. Heres my system specs....
CPU-Z Report
CPU-Z version 1.32.1.
CPU(s)
Number of CPUs 2 (1 Physical)
CPU#1 APIC ID = 0
Name Intel Pentium 4
Code Name Northwood
Specification Intel(R) Pentium(R) 4 CPU 3.40GHz
Family / Model / Stepping F 2 9
Extended Family / Model 0 0
Brand ID 9
Package mPGA-478
Core Stepping D1
Technology 0.13 um
Supported Instructions Sets MMX, SSE, SSE2
CPU Clock Speed 3391.5 MHz
Clock multiplier x 17.0
Front Side Bus Frequency 199.5 MHz
Bus Speed 798.0 MHz
L1 Data Cache 8 KBytes, 4-way set associative, 64 Bytes line size
L1 Trace Cache 12 Kuops, 8-way set associative
L2 Cache 512 KBytes, 8-way set associative, 64 Bytes line size
L2 Speed 3391.5 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 256 bits
CPU#2 APIC ID = 1
CPU Name Intel Pentium 4 (logical unit)
Mainboard and chipset
Motherboard manufacturer Intel Corporation
Motherboard model D875PBZ, AAC26680-205
BIOS vendor Intel Corp.
BIOS revision BZ87510A.86A.0125.P34.0503312215
BIOS release date 03/31/2005
Chipset Intel i875P rev. A2
Southbridge Intel 82801EB (ICH5) rev. 02
Sensor chip ITE F0D1
FSB Select 800 MHz
Performance Mode enabled
Graphic Interface AGP
AGP Status enabled, rev. 3.0
AGP Data Transfer Rate 8x
AGP Max Rate 8x
AGP Side Band Addressing supported, enabled
Memory
DRAM Type DDR-SDRAM
DRAM Size 2048 MBytes
DRAM Frequency 199.5 MHz
FSB:DRAM 1:1
CAS# Latency 2.5 clocks
RAS# to CAS# 3 clocks
RAS# Precharge 3 clocks
Cycle Time (TRAS) 8 clocks
# of memory modules 2
Module 0 OCZ DDR-SDRAM PC3200 - 1024 MBytes
Module 1 OCZ DDR-SDRAM PC3200 - 1024 MBytes
Software
Windows version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX version 9.0c
RBBRMADE
491
Is there any indication of an error in your event viewer?
Start, Run, eventvwr
Check System and application for errors at or about the time of the reboots.
Ron
FNP90
160
Ron, thanks. I didn't know I could do anything like that. The easy media creator program seems like it might be the culprit. I just installed it and there was no problems on my old hard drive so, I'm not to sure how to fix this, have some reading to do. It's easy media creator 7.5. So, my temps are fine, nothing to worry about there? Heres the only error I could find.
Details
Product: Windows Operating System
Event ID: 7000
Source: Service Control Manager
Version: 5.0
Symbolic Name: EVENT_SERVICE_START_FAILED
Message: The %1 service failed to start due to the following error:
%2.
Explanation
Service Control Manager (SCM) could not start the specified service, probably because the service is not configured correctly.
User Action
Do one or all of the following:
Review the error information displayed in the message.
Verify that the service password has not expired.
Verify that the service is in the correct location.
Verify that the service is not infected with a virus.
To display the WIN32_EXIT_CODE error that SCM encountered when trying to start the program, at the command prompt, type
sc query service name
The information displayed can help you troubleshoot possible causes for the error.
If the WIN32_EXIT_CODE is zero, then SCM did not attempt to start the service because the error was detected first.
Version: 5.2
%2
Explanation
User Action
Related Knowledge Base articles
You can find additional information on this topic in the following Microsoft Knowledge Base articles:
? "Event ID: 7000" or "Event ID: 7013" Error Message When You Attempt to Start a Service
Describes a problem with logon failures when you try to start a service. Provides several resolutions.
? "Event ID: 7000" Error Message When ASCTRM Service Does Not Start
On a computer that is running Windows NT 4.0, Windows 2000, or Windows XP, when you install or remove RealNetworks RealPlayer 8, or when you install or remove a program that installs RealPlayer 8 (for example, Netscape Navigator), the following...
? Availability and description of the Port Reporter tool
Describes the Port Reporter tool that you can use to log TCP and UDP port activity on computers that are running Windows Server 2003, Windows XP, and Windows 2000. Contains information about how to obtain, install, and configure the tool.
? You cannot log on or you experience a long delay on a domain controller or on a member computer that is running Windows 2000, Windows XP, or Windows Server 2003
Describes a problem that may occur if one or more services that run in the Lsass.exe process or in the Services.exe process are no longer configured to run as shared service processes. Lists the symptoms of this problem.
? Your Windows XP computer stops responding after you log on
Provides a resolution for an issue that occurs when you log on to a computer that is running Windows XP, an "Applying local settings" message appears, and the computer stops responding.
? "CD Recording Software Will Cause Windows to Become Unstable" error message when you start Windows XP
Explains why you may receive a ?CD Recording software will cause Windows to become unstable? error message when you start Windows XP. The article contains a workaround.
RBBRMADE
491
Have you considered Nero?
I like version 6 better than the new one, and it seems to be super stable, especially compared to Roxio.
Glad to help,
Ron
