I've got this problem limited, but I can't completely get ri of it. I get the following two error messages.
Event Type: Information
Event Source: Save Dump
Event Category: None
Event ID: 1001
Date: 11/15/2003
Time: 3:07:24 AM
User: N/A
Computer: CRASHIE
Description:
The computer has rebooted from a bugcheck. The bugcheck was: 0x1000007f (0x00000008, 0x80042000, 0x00000000, 0x00000000). A dump was saved in: C:\WINDOWS\Minidump\Mini111503-01.dmp.
Event Type: Error
Event Source: System Error
Event Category: (102)
Event ID: 1003
Date: 11/15/2003
Time: 4:25:28 AM
User: N/A
Computer: CRASHIE
Description:
Error code 1000007f, parameter1 00000008, parameter2 80042000, parameter3 00000000, parameter4 00000000.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 53 79 73 74 65 6d 20 45 System E
0008: 72 72 6f 72 20 20 45 72 rror Er
0010: 72 6f 72 20 63 6f 64 65 ror code
0018: 20 31 30 30 30 30 30 37 1000007
0020: 66 20 20 50 61 72 61 6d f Param
0028: 65 74 65 72 73 20 30 30 eters 00
0030: 30 30 30 30 30 38 2c 20 000008,
0038: 38 30 30 34 32 30 30 30 80042000
0040: 2c 20 30 30 30 30 30 30 , 000000
0048: 30 30 2c 20 30 30 30 30 00, 0000
0050: 30 30 30 30 0000
I started having some BSODs and reboots not long after installing the 3.8 catalysts. I've done the fixes I could find with Google, and although the problem seems diminished it still happens. I'm concerned it may be a hardware failure since I've had several reboots while reinstalling or fresh installing XP. The reboots occur when I'm installing or registering components. I always get the second error if I try to run TiVo with the 9700 AIW (usually as soon as I start it). I've tried ATI, but since I'm not under warranty any longer they're slow to respond. I've tried turning off system restore, fast writes, etc., but nothing seems to work. I've also tried selective device loads. Any ideas or suggestions would be greatly appreciated.
P4P800-D
2X256 KHX3500
9700 AIW Pro
Antec True 480
WD Raptor and 80GB Caviar SE
SB Audigy 2
Event ID: 1001
Date: 11/15/2003
Time: 3:07:24 AM
User: N/A
Computer: CRASHIE
Description:
Event Type: Error
Event ID: 1003
Date: 11/15/2003
Time: 4:25:28 AM
User: N/A
Computer: CRASHIE
Description:
Data:
P4P800-D
2X256 KHX3500
9700 AIW Pro
Antec True 480
SB Audigy 2
