Originally posted by: Jenova314
Originally posted by: Yo2
Basically both numbers have nothing to do with one another. As long as the voltage is between 15 and 20V this thing should charge any laptop battery.
The power adaptor rating indicates how fast it may be able to recharge a battery. 75W means it can provide up to 5A into a 15V battery or 3.75A into a 20V battery. This corresponds to the duration it will take to recharge the battery.
The battery rating in( also in watts e.g. 72W or 94W ) is basically just a number that states how long the battery will last.
where do i begin... wattage is the RATE of power delivered, you got that right in the 2nd paragraph, but then changed your mind again in the third paragraph when you used wattage as CAPACITY.
lets deal with the second paragraph first. the max power rating on an adapter is usually the maximum wattage an adapter can push through, NOT how quickly it can charge a battery. the amount of current used to recharge the battery is determined by the internal circuitry within your laptop. if you try to pump 5A into a battery to recharge it, you'll find yourself looking for another battery on eb@y pretty soon (unless it's a huge battery).
now your third paragraph.... the battery rating in W (if they actually have a rating like that) would be the maximum rate of output power able to be delivered from the battery, NOT the capacity. capacity would have to be power*time, or watt-hour, or Wh. hope this helps.
so to answer kalster's question: yes you can use the adapter safely since your laptop never really draws power to the maximum wattage anyways.
