- Jan 31, 2004
- 665
- 0
- 0
I can't get the two rear speakers to work. They're plugged in right on my NF7-S. Is this a driver issue or is there any utility I can use to correct this?
Originally posted by: GonzoCircus
They're plugged into my mobo(NF7-S rev.2), so that is what I have for sound. Sorry, thought I was clear about that. And I'm running XP.
The rear speakers work, messed around a bit and could hear muffled center speaker through them, I just cant get the rear speaker audio to go through them. Control panel doesn't help - have 6 speaker system enabled, but the rear channel audio is coming through the front speakers.
K I will do it for you NVSwap Play with this it will fix the routing of the sound.
