rear right speaker has very low sound - Logitech Z-560's
Chau
i have a set of logitech z560's and the rear right speaker has very low sound.. i switched the speakers around and plugged them into the sub and figured that whatever speaker that's plugged into the Right-Rear holes of the sub, that speaker will have very low volume compared to the other speakers.. any idea what this could be?? would i need to replace the sub?
thanks
Loose connection? Maybe you can curl up the wire and shove it into the connector to get more pressure from the clamps.
