- Dec 5, 2011
- 2
- 0
- 0
I have been working to consolidate all my digital music into my computer and connect the computer to my home stereo system. This has been going well but for the inability to get the S/PDIF interface working. I've read and re-read all the relevant manuals, updated the [FONT=inherit !important][FONT=inherit !important]drivers[/FONT][/FONT]
(twice) and confirmed that the S/PDIF interface is at least electrically working - the red LED is on.
Here are the particulars. Can anyone comment on what I am missing or need to do?
Computer:
- OS, Win 7 64-bit
- Computer, Intel DG43NB mobo with Q6600 CPU
- S/PDIF, mobo header with Asus S/PDIF back card - wired red+5, black-ground, brown-S/PDIF
- Audio chip - RealTek ALC888VC
- Drivers, initial setup - Windows audio, upgraded to RealTek 6.0.1.6201 using auto update, then upgraded to 6.0.1.6482 from RealTek site
Stereo
- Sony STR-AVDE545
- Digital interface, S/PDIF (2-CD, DVD) and co-axial
Wiring
- 50' fiber cable
One issue I have is the fact that the stereo operation mode is unclear. The
[FONT=inherit !important][FONT=inherit !important]user's [/FONT][FONT=inherit !important]manual[/FONT][/FONT]Here are the particulars. Can anyone comment on what I am missing or need to do?
Computer:
- OS, Win 7 64-bit
Stereo
- Sony STR-AVDE545
Wiring
- 50' fiber cable
states that it has two digital modes, an analog mode and an automatic detection mode. It then implies that if no digital signal is detected it will only operate in the analog mode. This is what it is doing - pressing the analog/digital switch does not change modes. I am assuming from this that no
[FONT=inherit !important][FONT=inherit !important]digital [/FONT][FONT=inherit !important]signal[/FONT][/FONT] is reaching the stereo, even though the fiber cable is emitting a red light.
My suspicion is with the drivers and the settings for the S/PDIF interface in the computer. I found a RealTek document on line called "RealTek High Definition Audio",
http://uk.ts.fujitsu.com/rl/servic [...] 00_0418-05My suspicion is with the drivers and the settings for the S/PDIF interface in the computer. I found a RealTek document on line called "RealTek High Definition Audio",
[1].pdf, which describes all the various features and settings for an un-named RealTek driver or sound card; the document does not specify what it documents. That document describes a number of screens or panels that enable and control the S/PDIF interface. The controls that come with the RealTek drivers do not mention the S/PDIF interface at all and I suspect that the drivers loaded are either not aware of the S/PDIF interface or do not perform the control of it properly. The controls that come with the RealTek driver do not match the controls in the document noted in a number of areas as well.
I saw a post on line which stated that if the RealTek drivers did not detect a S/PDIF interface they would not present the S/PDIF
[FONT=inherit !important][FONT=inherit !important]control [/FONT][FONT=inherit !important]panels[/FONT][/FONT]I saw a post on line which stated that if the RealTek drivers did not detect a S/PDIF interface they would not present the S/PDIF
. I do not know if this is true. How can I confirm that the S/PDIF header and back card are working properly? No smoke can out when I connected up the wires and the red LED is on. What else can be tested?
I have only one yellow exclamation mark in my controls/device manager panel. The one exclamation is for other_devices/simple_communications_controller. I do not know what this is or if it relevant. The error for this is that drivers are not installed. A search for drivers using the update driver box does not find any drivers.
If the drivers and the S/PDIF header/back card won't work, what are my best options with a PCI/PCIe sound card? I would need S/PDIF but since the stereo will doing all the mixing and amplification, I would assume that I don't need a lot of features in the sound card itself. The plan is to have the computer essentially be a very smart CD changer.
