Really wierd stuff going on with my new 6950
Seero
1,456
can anyone tell me what they think this means (that the 5850 loses signal to the monitor after I power up a game) but lasts forever until then.
First, it seems your PSU is damaged because it shouldn't make any sound other then the loud coming from its fan. When it does make weird sound, it means it isn't functioning properly.
Second, your mobo may have been damaged due to the 6950 incident. You need to understand that the trip of the circuit breaker may be caused by a short happening within your PC. There are no circuit breaker within the system so a electricity surge may damage anything connected to the PSU.
Third, it is hard to say what exactly is the problem as it can be a number of things. The best way is to bring it to a shop and have them cross check each component as they have lots of spare parts. Usually I will suggest people to try to find the problem themselves first, but a) your problem isn't localized and b) you don't take precaution when it comes to computer parts. A CPU HS may fall off or not assemble correctly by user, improper mounting happens and CPU has mechanism to prevent catastrophic cooling failure from damaging the system. That doesn't mean it is perfectly safe to operate a system without a HS. GPU HS are pre-mounted by about 10 screws, and it is not designed to operate without a HS, nor have mechanism for cases like that. Other that the HS, the thermal pasting is very important too as it will lead to cooling failure if no installed properly. With lead to the next reason.
Fourth, you moved the HS left and right and complained about its noise and high temp reading. Well high temp reading causes the fan to spin faster, but faster spinning fan doesn't necessary mean it is moving air, nor moving heat to be specific. It sounded like the installation of the HS is problematic which ended up causing your 6950 to fail, and you probably used the same procedure to install it back to the 5850, which again ended up with high temps and loud fan. To ensure something will die, you run futuremark and SC2 over and over again, which are programs known to kill video cards with improper cooling.
Fifth, I am assuming you have put thermal pasting between the HS and the chip, but I also assumed that it was not done properly. I have heard people use "tooth paste" as thermal paste, so I can't be surprised anymore.
Have I answered your question?
Spikesoldier
6,766
you may have damaged your mainboard, not sure. but its interesting you bring up the psu.
it sounds like the card blacks out when it hits 3d clocks, but is fine at 2d clocks.
but if your psu is making noise perhaps its not working correctly and fails to deliver the required current to operate the vga card at 3d clocks.
Athadeus
587
Hey Josh, I'm not freaking out, just concerned for your computer's well being. I would be freaking out if my own equipment was doing the same thing (my Asus G73Jh laptop is in fact doing the same thing shutting down within seconds of running SC2). It sounds like you are having overheating issues as well as other problems potentially.
I wish you well in your troubleshooting efforts whether you decide to continue working at it yourself or to get help. Also, how are you at SC2? We should play some after you get it working well again.
Jeff
SpeedZealot369
2,778
What can it mean if the signal to the monitor gives after running furmark or sc2 for 4-5 seconds? but I can surf the net and watch an hd movie without any issues..
SpeedZealot369
2,778
Jeff
Hey that would be great I am a high ranking platinum toss.. love the game though so much fun and challenging.
badb0y
4,015
30
Thread title should be " Really wierd stuff I did with my new 6950"
Sorry couldn't resist but your going to have to get your hands on another PSU so you can see where the problem is.
SpeedZealot369
2,778
It means your system is not stable.
Can you elaborate on that please.
I have one on the way I will let you guys know what happens when I swap the psu out.
