Really Weird Video Problem.. Come on Geniuses help me out!!
Josh64FX
969
I have an ATI X1950pro and an Asus M2N-sli deluxe motherboard and the DVI does not work but the VGA works fine.. No display on the DVI, in windows it says no devices attached when I try to DUAL it on the DVI.
So I took the ATI X1950pro out and hooked it up to an ATI A8R-MX board and the DVI and VGA works fine.
Both were hooked up to the same monitor..
So does that mean, my M2N-sli deluxe motherboard is defective? Never seen a mobo restricting DVI out.
conlan
3,395
Open CCC and check if "Reduce DVI frequency on high-resolution displays" and "Alternative DVI operational mode" are enabled
Make sure your refesh rate is set to 60Hz
I went through this very thing this weekend, it was the refresh rate
Captante
30,340
10,859
CCC is the ATI driver control panel & I think he means connect your moniter via the analog port & check the settings that way.
conlan
3,395
Yes, thanks Capante, i should've been more specific. :)
conlan
3,395
So when you say your trying to different mobos, you're actually trying two different systems, correct?
Josh64FX
969
well once I start the system, VGA posts fine but DVI does not post.. This is on the M2N-sli deluxe
On my other system, Asus A8R-MX, DVI and vga posts fine..
I am not even in windows
conlan
3,395
Check your monitor menu, scroll through and see if it is receiving a Digital signal, if not, make sure you have power to the PCI-E connector at your Video Card, and that your Video card is fully seated.
