I have an ABit KR7A mobo, XP1900+, 256MB PC2700RAM.
The computer starts up, fans all come on and everything, HDD light flashes, stops flashing etc, network card is fine.
CD/DVD drives look like they are detected (lights come on the go off after a bit, like normal).
Only one problem:
The monitor doesn't show anything at any stage of the possible boot (so I can't be sure it's booting up).
Monitor works fine (LCD with VGA input, tested as a second monitor on my 9800Pro and it works).
Graphics card is a Ti4400 which powers up (ie: the fans spins) but the monitor doesn't show anything.
A GF2 MX400 also has same problem (no monitor output) - no fan to check it gets powered up.
Everything else *seems" to do normal boot stuff, hdd comes on then goes off after a time etc.
Only problem I know of is no screen at all, not even a BIOS/POST type thing.
Since 2 graphics cards haven't worked, and the monitor is fine, and everything else appears fine, from what I can know, what could be the problem?
Would the computer even begin to boot if no AGP card was detected (don't have any PCI cards unfortunately 🙁), because it seems odd that it might, and the fan on the graphics card span up and was fine.
I have reset the BIOS, no joy.
Unfortunately I don't have logon password so I can't see if it gets to logon screen and stuff "behind the scenes", but will try and get it sometime.
I don't know what else could be wrong, as all the other parts did work, and the computer used to boot up.
Any ideas?
Only one problem:
Any ideas?
