Hi,
I really need help on this. I can't even boot up.
I've been reading ton and tons of post while waiting for my mobo to come in.. Anycase I finally received everything today. Here's what I have:
Asus A7M266
2 x Crucial CT3264Z265 (256MB, PC2100 DDR)
Millenium 2 PCI card and a NVIDEA card (not sure what model at the moment)
AMD 1300 package (1.3GHz w/ heatsink & fan)
Newton Power Supply (from a Gateway computer) Output 200W Max
+5V 18A, -5V 0.3A, +12V 6A, -12V 0.3A, +5VSB 0.7A, +3.3V 10A)
(Yah I know it's weak but I got a 300W coming in a new case soon
What I did initially:
I removed the VIO1 pin to get the 2.5V.
I didn't install the audio card (figured to keep it small to get it up the first time)
I installed the NVIDIA card into the AGP slot
I installed 1 256MB DIMM (Like I said, keeping it small)
I installed 1 IDE HD w/ Win2k
I installed the floppy drive.
No internal speaker (case didn't have one)
Okay it's all standard stuff, Well I booted up and it went to BIOs directly, I set the settings to Turbo, and the BUS to 133MHz. Seemed reasonable. Anycase I then Saved and rebooted.. and only got a orange light off my monitor for my trouble. Power button didn't have a response so I have to pull the A/C plug.
What I tried:
I've tried running VIO1 at 2.7V, and 2.5V.
Swapped the memory with my other crucial (remember I bought 2)
I've even tried both memories in the slots
I've swapped out the NVIDIA with a Millenium 2 PCI video card
This is the first computer I've built with a ASUS motherboard.. not too inspiring except that everyone tells me it's a good company. Anycase the only guess I have is that the power supply is way too weak.. Only logical guess I have.. andycase I'm going to pick up one tomorrow if my new case doesn't come in yet (stupid company sent me the case with the screws all rattling around, scratching the case up
) If anybody has had any trouble like this and it wasn't a PS problem, please let me know.. Thanks in advance.
There are just some days I feel like I should have stayed in bed.. today is one of them.
Asus A7M266
What I tried:
