Background: Working on a friend's computer so I don't know all history. Sound was working fine before playing at normal volumes: suddenly started playing really low at max volume. I can verify that it used to be fine before and now plays really low, but I don't know for sure what happened in between.
Symptom: Sound is barely audible. Seems to only play out of left speaker (2-channel speakers.)
Details: Using powered logitech speakers. Plugged into (lime) green output on rear of computer. Motherboard is MSI P6N SLI with a Realtek HD Audio chipset. Running Windows XP Pro w/ SP3. Running latest MSI drivers from February 2009.
Troubleshooting: Tested using headphones, same result. Tested speakers on other system: work fine. Verified sound levels in: speaker volume knob, windows voume control (advanced controls as well), control panel -> sounds and audio devices, realtek hd audio manager (even discovered secret volume controls for each physical output - no effect.) Installed latest MSI drivers. Ran Spybot, AVG, Windows Defender scans (I have found a persistent trojan that I can't kill yet.) Uninstalled all third party sound codecs I could find. Installed CCCP.
Partial Solution: Plugged speakers into rear blue output (normally used for rear channel speakers I believe) and using the Realtek HD Audio Manager set it to output front channel sound via this output. Everything works fine now. I hear sound at normal levels out of both speakers.
Help: I hate to leave a problem unsolved. Using the blue output is a hack as far as I'm concerned. I need ideas as to why the normal green Line Out is not working...
