I am running two WD 120GB hard drives in portable bays in the 5 1/2 inch slots so I can transfer them to and from. Well, I've had problems with a hard drive and I'm curious to know if it's heat. Not every day, not all the time, but every once in a while, possibly after a big load, my hard drive starts stuttering like it's trying to shut down or cycling. You can see the hard drive light flicker on and off in a steady pattern. And I think you can hear a little clicking.
I don't know much about the internal part of the hard drive but my suspision is that it's so hot that it's starting to fail. Should I be concerned about this? I thought I had good airflow because there's a fan at the back blowing either in or out of the bay, not sure which one.
Any suggestions?
Any suggestions?
