Hi everyone,
I'm a little confused about thermal compound and pads so I'm looking for opinions on my specific Heatsink/Fan (Taisol) and my CPU(900 mhz TBird).
Ok....
1. My "AMD approved" taisol has a thermal pad on it. I hear it is good but how can it *possibly* dissipate heat over the surface of my CPU???? It's only about an inch by an inch!
2. I also ordered some gray "Shin Etsu G749 Thermal Grease" thermal compound from Taisol. Which should I use, the grease or the pad?
3. If I should use grease, should I cover the surface of my CPU only or the entire surface of the heatsink? The surface of the heatsink is a lot bigger than the CPU.
4. Also if grease....Some say wiggle the heatsink a bit to get rid of trapped air, some say don't wiggle it to avoid creating air pockets....which is it?
Thanks in advance!
Zlady
Ok....
Thanks in advance!
Zlady
