Really annoying problem/defect with a K9A2
Valis
The computer with this mobo (K9A2 Platinum) has Phenom 9550 BE, 4GB Corsair mem, ASUS ATI 4850 and a Corsair 550W PSU.
The BIOS boot screen and Windows boot are really slow too. But the real problem is that once in Windows (XP 32), the system works ok for a few moments, and then completely stops/freezes for a few secs 5-10s or so, and then works fine for a few moments, like 15-30secs, and then stops for 5-10secs, and it goes on like that. Really annoying glitch.
If you use firefox or play a modern 3D game, it stops/works/stops the same way.The sound goes in a loop too, mostly.
Any ideas? I re-installed this mobo after a Giga MA970X-DS4 failed due to some component failure (you had to switch it on and on like many times before it started, it kept turning itself off at first, sometimes 5 times, the 30, etc, finally it gave up completely).
I'm ready to toss with K9A2 too, I have swapped out GFX card, mem and HDD over the course of time and trails with this cursed computer.
Any similar experiences would be nice to hear about.
Mat
Flash to the latest bios and do a fresh format using Windows 7. Windows 7 has most drivers built in so we can eliminate a driver problem.
This was something that started a while ago, it was working fine at first for some time. I dunno, months or so.
Could try some other drivers, sure...
