Since i was installing a OCZ SSD I got the program CrystalDiskInfo and it said one of my current disks is at a "caution" level. Threshold for warning was "5" which I assume is more than five sectors reallocated.
It is a older SATA 160Gb but none the less I store stuff on it so I moved it off, deleted the partition, repartitioned it and low level formated it, then high level "windows" formatted it. Did not change the warning.
Also the program I used to low level format is: a low level format program from "hddguru.com
So just throw out the hard drive?
Also the program info said not NOT to low level format a new hard drive. Why?
