Originally posted by: Powernick50
Originally posted by: RallyMaster
Did you reformat after installing the video card?
Nope, should I have?
No....reformatting to solve problems is just the clod's way of dealing with anything beyond their comprehension. Whenever there's a problem that could remotely be associated with drivers/software incompatibilities, the simpleton answer is always "Reformat and reinstall your OS."
About your power supply.....it should be enough, more than enough actually, to run your video card. But I never was really impressed with the 750's build...OST main cap and Ltec secondary caps. Neither brand is above mediocre and while no huge waves of failure complaints are around, the build just didn't suit me. (I did buy one, but after doing further reading after its purchase, I returned it.) The recommended ps is 500W or better, and since yours can deliver up to 19A on the PCI-e connector, and the card can draw around 12.5-13A via its two 6-pin connectors, the only thing I'd consider is what rail you've got the video card on. I'd try to ensure it's using a rail by itself....your manual should spell out what rail is powering what cables/connectors.
Now, are you using the CCC 8.6 AND the hotfix CCC drivers? Make sure you apply the hotfix drivers if you haven't already done so.
And how hot is the card getting while at full tilt? I'd look into editing a profile to run your fan at 50% speed, minimum. How to do this is located in the other longer 4850/4870 thread(s).
I'd really think it's either a driver issue or heat issue....not a "You gotta reformat your hard drive," issue.
