Many of us have found out the hard way that readyboost doesn't actually do anything to improve performance. Although readyboost tries to read from flash, Windows is still writing the swap file to the hard drive as well as the flash. If you're trying to access the hard drive while it's writing to the swap file, the computer drags ass and is virtually unusable. This is why readyboost doesn't work, but it can be fixed with a little bit of tweaking.
Step 1: force Windows to see your USB drive as fixed
Changing the "removable media bit" on a flash drive is done with a program called BootIt. Download the program from this page (the link is on the bottom left). Run the program, select the drive letter of your USB drive, hit the "flip removable bit" button. Here's a picture:
http://img189.imageshack.us/img189/9895/bootit.jpg
Now the USB drive should appear as a fixed drive in windows explorer. In this picture, G is a flash drive:
http://img188.imageshack.us/img188/2176/localdrive.jpg
Step 2: put the swap file on the USB drive
take the swap file off every drive except the USB drive
Here is a picture:
http://img46.imageshack.us/img46/6669/pagefile.jpg
Step 3: restart computer
restart the computer...
Step 4: check if it worked
Open performance monitor (vista only) and check if your USB drive has any activity on a file called "pagefile.sys"; here is a picture:
http://img132.imageshack.us/img132/7651/perfmon.jpg
And now the computer will run faster. My file server is quite a bit faster after doing this because all of its drives are cheap shitty drives; the ones that are $100 for 1000gb. If your system is like mine and it contains literally the cheapest hard drives you can buy, putting the swap file on a USB drive makes a world of difference.
Here is a picture:
