This is my first computer I'm assembling from scratch and I've got no clue what part models mean these days so I'm kind of a noob because I've been out of the computer scene for a while. I need some last minute suggestions/advice before confirming my checkout as I pretty much just placed what I saw other [hard]posters using on the forums. I plan to push a high-mid OC (3.0-3.2) with a 24" LCD monitor so below's a few parts I'm concerned may be below par for the rest of my rig or make a bottleneck and maybe I should replace them now before I order this stuff today. Any suggestions are greatly welcomed.
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Processor Model BX80562Q6600 - Retail - 280$
http://www.newegg.com/product/...p?item=N82E16819115017
GIGABYTE GV-NX88S640H-RH GeForce 8800GTS 640MB 320-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card - Retail - 360$
http://www.newegg.com/product/...p?item=N82E16814125050
ABIT IP35-E LGA 775 Intel P35 ATX Intel Motherboard - Retail - 119$
http://www.newegg.com/product/...p?item=N82E16813127031
WINTEC AMPX 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model 3AXT6400C5-4096K - Retail - 200$
http://www.newegg.com/product/...p?item=N82E16820161183
Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM - 80$http://www.newegg.com/product/...p?item=N82E16822148140
LITE-ON 20X DVD±R DVD Burner With 12X DVD-RAM Write Black SATA Model LH-20A1S - Retail - 36$
http://www.newegg.com/product/...p?item=N82E16827106057
CORSAIR CMPSU-520HX ATX12V v2.2 and EPS12V 2.91 520W Power Supply - Retail - 139$
http://www.newegg.com/product/...p?item=N82E16817139001
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail - 139$http://www.newegg.com/product/...p?item=N82E16811129021
Thermalright Ultra-120 Extreme CPU Cooler - Retail - 65$
http://www.newegg.com/product/...p?item=N82E16835109140
Microsoft Windows Vista 64-Bit Home Premium for System Builders Single Pack DVD - OEM - 112$
http://www.newegg.com/product/...p?item=N82E16832116204
(4x) APEVIA CF12SL-UBL 120mm Blue LED Case Fan - Retail - 26$
http://www.newegg.com/product/...p?item=N82E16811998121
Kensington 64338 Black USB Wired Ergonomics Comfort Type Keyboard - Retail - 14$
http://www.newegg.com/product/...p?item=N82E16823155004
Arctic Silver 5 Thermal Compound, Already have a mouse.
1. Overall how does it look? I'll be using a 24" lcd and I want to this thing to last sometime and play games at max or close settings. Any suggestions?
2. How many fans will I need (including the PSU fan)? I currently ordered 4.
3. The motherboard was only $119 they had another same version for 149, should I spend the extra 30$ or is the current good enough?
4. That Wintec RAM was the cheapest. For 20 bucks more they had G.skill should I get that instead?
5. For a complete system configuration is there anything I'm missing (wires/pastes/fans ect.) The above order is my exact.
