- May 29, 2002
- 3,286
- 0
- 0
I want to learn how to read these things. For example, what size hole and what type of screw does a 3/8-16-NC tap require? What does the NC and the -16 mean? 3/8 = requires a 3/8 inch hole?
It's for a 5/16... I don't need help, just wondering how you read and interpret all the labels.Originally posted by: xSauronx
if the chart isnt included with your die set youre fuxor3d
you dont make the hole you want to tap the same size as the tap/die, or itll just go right into the hole wont it?
so, the pilot hole has to be slightly smaller than the desired finished hole.
yes, the -16 is threads per inch (which would be a coarse thread, fine would be something like 24 or 32 for very fine)
been a while since i used one, and even then it wasnt terribly often. id guess the piece labeled 3/8 -16-nc is for something like a 5/16 bit? maybe a 9/32? go by a hardware store and they could probably help you, or hell, call one for gods sake
Well, how would I know if the 3/8 meant something else? It says 3/8, what else am I to assume? I want to know what the markings mean, I'm not looking for charts.Originally posted by: Ornery
"3/8 = requires a 3/8 inch hole?"
You DO need help, and eplebnista gave it to you, with no thanks I noticed.
I wouldn't waste my breath on this ungrateful turd.Originally posted by: WhiteKnight77
Ok to read the tap chart, remember that the size of the tap is gonna be bigger than the hole that has to be drilled. As you tap the hole, you are physically cutting the threads and making the hole bigger (to the size listed on the tap IE. 3/8".) A 3/8"x16 tap uses a 5/16" drill bit likewise a 7/16"x14 tap willl use a #U drill bit.
Likewise. Don't deal with a person when he's really pissed off.Originally posted by: Ornery
Thanks for the basic help... what's with naming drill bits with letters, anyway? Thanks to the guy above for explaining the whole it-turns-into-a-3/8-hole type thing.Originally posted by: Roger
3/8ths would be the diameter of the thread, not the hole.
3/8 - 16 would be a 3/8ths thread diameter with 16 threads per inch.
NC = National Course
NF = National Fine
Both the above terms relate to the shape of the thread as well as how many threads per inch.
I finer thread requires a different tip shape (Crown) than a course thread, thus you have the two different standards.
Metric threads are another story, you have course, medium and fine but with one tip shape standard.
I am not even going to bother to try to explain pipe threads until you understand these basic terms first.
I don't even understand pipe thread and I am a mechaic too. All I know is my air tools use a 1/4" fitting.
Number and letter bits have to do with machining and machine shop processes.
And your welcome.
I thought you thread a pipe with just a really big die?Originally posted by: Antisocial-Virge
And your welcome.
Pipe thread just tapers so eventually it "gets stuck".
Two common pipe thread sizes exist, the tapered National Pipe Thread (NPT) and the straight National Standard Free-Fitting Straight Mechanical Pipe Thread (NPSM). The tapered threads are for joining and sealing, the straight threads are only for joining. The Dry-seal thread (NPTF) allows for joining without sealants. Three less common threads exist, the Garden Hose Thread (GHT), Fire Hose Coupling (NST) and British Standard Taper Pipe Thread (BSPT). The NPT and NPTF threads are interchangeable with sealants such as PTFE tape. None of the other thread standards are interchangeable. Female NPT threads can be designated as "FPT" and male NPT threads can be designated as "MPT."
NF = National Fine
