Reading a file using c++ need a little help in reading columns
DAWeinG
2,839
My friend needs help reading the rows of a file:
The file looks like this:
L D Q
34 2 1
45 3 2
23 1.5 0
I need the program to READ the separate doubles there and store them each into a variable, (ie. x = 34, y = 2, z = 1); Each three numbers of a row at a time.
Suggestions? TIA
notfred
38,241
4
I haven't worked in C++ for a while, but it's something like:
int array[50];
for(int i = 0; i <50; i++){
aw, hell, I can't remember.
in perl you can do this:
open (FILEHANDLE, "filename");
@array_of_lines = <FILEHANDLE>
foreach $line(@array_of_lines){
@numbers = split /\s/, $line;
#do whatever you need with $numbers[0], $numbers[1], $numbers[2]
bUnMaNGo
964
is it *always* going to have the first two lines, then having three doubles per line? without error checking, you can do something like:
inFile >> a >> c >> d; // assuming x, y, z are chars
inFile.getline();
while(inFile >> x >> y >> z){
// do whatever you want with x, y, and z here
you might have to fumble around with the getline to get rid of the \n at the end of the first two lines. but this is pretty much it.
DAWeinG
2,839
Hmm ya there two lines are always going to be there :( How can I skip those two lines? Is there a command which allows me to do that?
Platypus
31,046
321
you want to use a getline. Why don't you store the entire line as a variable and then make a function that seperates the numbers into smaller variables using spaces etc.
Ex: 34, 2, 1 = variable 1
Then run variable 1 through your function and seperate each one into seperate variables.
It may seem like a lot of work, but if you have a lot of those lines, making two loops is a lot easier then doing it with arrays.
bUnMaNGo
964
err the first two lines of my code should do it... read in the first three characters, then just getline the next line... as I said the getline might grab the '\n' from the first line, so you might another getline to get the 2nd. let me know if it works.
