Question Read speed in HDD
Did you run trim before running the test? This is a SSD drive, right?
I'm not familiar with HD Tune Pro. I use CrystalDiskMark as I see it on sites all the time.
If by 'time' you mean the time it took to run this test: That's a perfectly ordinary performance curve because you won't ever get uniform performance right across the platter. The figures look reasonable too me too.
Thank you for your answer, Could you please more explain about it?
