looper
Basic 'GoodOldGames' Commander Pack version of TA running fine...
But when I try to install the TA Escalation mod, I get an error message, "...some prerequisites missing...the 'Visual C++ SP1 Redistributable' needs to be installed", I DL that and attempt to install it. I then get "install failed, some prerequisites are missing..."
HELP............... thanks.
EDIT......
Ok, I think this is what is FUBAR....
I just checked in "Control Panel/Installed Programs'.... is the following:
*MS Visual C++ 2010(x64) Redistributable 10.0.40219
*MS Visual C++ 2010(x86) Redistributable 10.0.40219
*MS Visual C++ 2012 Redistributable (x64) 11.0.6103.0
*MS Visual C++ 2012 Redistributable (x86) 11.0.6103.0
*MS Visual C++ 2013 Redistributable (x64) 12.0.30501.0
*MS Visual C++ 2013 Redistributable (x86) 12.0.30501.0
*MS Visual C++ 2015 Redistributable (x64) 14.0.24210.0
*MS Visual C++ 2015 Redistributable (x86) 14.0.24210.0
What the heck........is this part of the issue, and anyone know for sure what I need to do?
EDIT......
