RE: Conair - Could an airplane do this?
JMWarren
1,201
I've know idiots at the local flying club to take of in a 172 or 152 forgetting to remove the concrete filled truck tire thats attached to the tail tie down point. Consider a 152 only has 110 HP (Probably less most are 30 years old) and a fully loaded weight of under 1700lbs, The corvette should be easy for a decent sized jet.
Scarpozzi
26,392
1,780
You're comparing a prop plane to a jet....there's little comparison when it comes to thrust...
The problem with dragging a car behind the cargo plane isn't that it couldn't pull it off the ground. Considering that a car travelling over 150mph that gets wind under it will basically fly, that's fine and dandy. The problem is that once airborne, it's NOT aerodynamic. It would be flopping around and subject to so many forces that it would cause the plane severe problems and the weight and drag could potentially rip the aircraft's structure apart. I believe in the movie, it was tied off inside somehow....it would have ripped whatever it was tied to apart....potentially broken the chain or straps holding it.
Otherwise, there would have been another weak link that would have broken. If it had not, the plane would be pulled down by the drag and the pilot would have little chance of getting it to respond. The severe drag of the car pwns what an elevator, and aliarons can do to control the aircraft.
JulesMaximus
74,586
986
Originally posted by: MS Dawn
Originally posted by: JulesMaximus
The car would be flapping around like a toy behind the airplane as soon as it left the ground.
I don't think Mr. Bernoulli agrees that the effects of the craft's wake and non laminar flow around the car would produce a force sufficient to alter its course while in flight at that speed but then again - let's test it out! :D
Okay, we'll use your car mkay? ;)
LordMorpheus
6,871
yeah, it would probably be hanging lower than in that picture, too.
tyler811
5,385
Originally posted by: ATLien247
I'm surprised you're asking such a question, MS Dawn. I thought you knew everything about everything!
Hardly but I like to share with others so everyone gets smarter in the end. :)
Sometimes the insane make the most sense on crazy days. ;)
Oh and I hate airplanes. :p
Actually I like reading Ms Dawns posts. I have learned a thing or two by reading them.
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
http://forums.anandtech.com/messageview...atid=42&threadid=1966333&enterthread=y :p
Feb 19, 2001
20,155
23
ever strap a paper sign to a paper airplane? It spins and twirls out of control (the sign). The car if behidn hte 747 might be able to do it (far behind), like maybe 200 ft behind it. But I think the car woudl be spinning and whatever instead of remaining right side up like in conair.
Why a 747... They should try a 777. Those throw out like 80,000+ lbs of thrust. The engine itself is as big as a 737 fuselage. 747s don't even have the most powerful engines. Plus they only turned 2 on at a time. Imagine if all 4 were running =)
Rubycon
Madame President
Aug 10, 2005
17,768
485
Originally posted by: mercanucaribe
That depends. Is the plane on a conveyor belt?
They tied it to one and the other side is attached to the undercarriage of the most outrageously expensive sports car in the world.
skyking
22,802
5,971
Originally posted by: Googer
Towing a car with a large plane is on the same scale as a small plane towning a non-aerodynamic banner
I've got 500 hours or so pulling banners. The biggest ones, 30' x 120', weigh in at about 100 pounds. We pulled those with 180HP C170's and C175's, CS props, STOL wing mods, and stripped down to a bare minimum.
Those signs have tails with pockets to catch the air and straighten or stabilize the sign. The lead poles have weights to get them started right side up, and the bridle is asymmetrical also.
The car thing is fairly improbable due to aerodynamic instability. It could not generate enough lift to overcome weight, nor would it behave nicely back there in the tow. It would fishtail around like a broken lead pole does. That sucks, a crappy feeling when you are getting steered around by the tow.
The CG change would likely be a dealbreaker in itself.
Martin
29,178
Sure it could - the corvette only weighs around 3000 pounds (or 10 American passengers).
