Re: Alpha 8045 HSF and Epox 8KHA+ mobo, will it fit???
RaymondY
1,627
Does the Alpha 8045 HSF fit on the Epox 8KHA+ motherboard without any modifications??
Plycon's website says that the Alpha contacts one of the capacitors. Comments? Recommendations??
LMK, Thanks
J.Zorg
47
The heatsink fits but is really close to one of the capacitors. You might have to modify the heatsink.
Here is a link where you can check it out and find some more informations about the Alpha 8045 HS on different motherboards.
