Originally posted by: bruceb
As long as you do not disturb the Tie Rod Ends or have to remove the
Strut Assembly (shock / spring) you will not need an alignment. But if
you do need to move the strut, then Scribe it's position before you remove it.
Also on most cars, you will need a large socket to loosen the nut on the end of
the Axle by the brake rotor ... That is usually fairly tight. Check shop manual for Torque.
While the axle is out, you should consider new Seals where it goes into the Transaxle.
Now is the time to change them, while you can get to easily. And since your brakes
will be apart to get the axle out, check your pads and rotors .. good time to change
if they are near end of life.
