I figured this would be an easy thing to do. I bought a Gateway 700x in March 2002, with a P4-2 GHZ Northwood CPU. I have 2 128MB rdrams in it (Samsung) and thought I would upgrade. The NewsGroups tell me no problem. PC800 is all the same...as long as you install the same size in each bank, and non-ecc.
So, off to look at 2 256MB pc800 RDRAM sticks. Kingston has some ValueRam KVR800X16/256 for $86 each. HOWEVER, the Kingston site says the "certified" RDRAM for the Gateway 700X is KGW800A/512...a 512MB KIT for about $350!!!!
So, I now have no idea what that means...Kingston just says that the KVR series is generic...why should this matter? I believe the Gateway Lexington is just an Intel D850MV MoBo...and the KVR is listed for that board.
TIA
TIA
