RCAs for my car amp
AMCRambler
7,715
31
This is probably a stupid question but I'm gonna ask anyway. I've got a set of those red, white and yellow cables you would use to connect something to your vcr. I know the red and white are the audio cables and the yellow the video cable. My question is are they just standard rca cables? I need two to hook up my new amp in my car. I'm 90 percent sure they are, but I figured one of you knows for sure.
amnesiac
15,781
Yup.
If you want a good install I'd recommend cables that are a bit heavier on the shielding; there's a lot more stuff in a car that can cause interference.
AMCRambler
7,715
31
Cool, thanks. I think these will work pretty good, they're not the thin cheapo ones, they're the Radio Shack gold series so they've got the nice ends on them and the thick shielding.
