RCA to USB 3 Cable
GPag
32
I want to connect a Sony digital camcorder, DCR-TRV510, to my laptop so I can transfer tapes. The camcorder has FireWire and RCA outputs. My laptop only has a USB 3 input. Do I just need an RCA output to USB 3 input converter cable or are there other configuration issues I need to worry about?
Thanks.
28,284
13,020
Isn't RCA just an analog output to hook it up to a tv for playback?
I'd try a FireWire to USB cable. But you may also need to dig up a driver if Windows won't recognize it.
mindless1
8,738
1,748
Agreed, converting analog to digital is going to be lower quality than keeping it digital with a firewire to USB converter/cable. I have seen some cables or just inline adapters that are just connector conversions, meaning a firewire on one end and USB on the other, and I don't think those will work, rather it needs to be an active adapter with a bridge chip circuit in it.
I saw this topic mentioning that, and it also mentioned S-Video. If it has S-Video that will be higher quality than the RCA jack output, but still not as good as keeping it digital.
How about a PC that you add a firewire card to if needed?
mindless1
8,738
1,748
^ That seemingly passive FW to USB cable is one that I saw not working in the link I posted.
