Originally posted by: Macro2
Try this...
Reset you modem defaults. On the RCA I have, you hold in the reset button with a paperclip or ballpoint pen and plug in the power cord at the same time.
If that doesn't work, RCA will usually send out a new modem if you give them your credit card and credit you when you send back your old modem.
That's if you own it and it's under warranty which is usually 2 years.
If it's comcasts modem it's THEIR problem.
You could also just have a weak signal. Make sure all your connections and splitters are tight. Also, how are your lower TV channels...like 3, 4, 5?
If they are bad you could just have a weak signal. Call Comcast.
Another option is that they are working on the lines somewhere.
Mac
Comcast gave me the modem, altho I had my own but it seems to be unsupported (DLink DCM200). I think the install tech may have goofed though. I was told that they need to split up the cable line at the point where the cable is dropped
outside the house. Instead, the tech put a splitter on the line that was already in my room which connected the TV to cable. This is sorta what it looks like:
outside line.......2way splitter.......3 way splitter.........my room splitter
------------------<-----------------------<--------------------------<----------------------cable connection
I was under the impression that this is the way it was supposed to be done:
------------------<-------------------cable connection
I dont know if it really makes that much of a difference, but while the modem keeps losing the connection, my speeds are always in the 1.7-2.0 mbps download range (I signed up for 1.5/256) when it does work.
Ill call em up today and see what they say about it
