JWMiddleton
I want to get clarification on a question I have. I have noted that your d.net id is in the dnetc.ini file. If you change that id with blocks in the buff-out file, what id gets credit for the blocks? It appears that whatever id is active while the block are being processed would get the credit. Is that correct? If you wish to change the id should you flush first, then make the change?
