GeoffS, Most of what you'll find in the .ini file is generated when you set up the client for the first time. The only things I do manually are:
[networking]
nofallback=true
[misc]
project-priority=RC5,DES=0,CSC=0,OGR=0
I'm a die hard RC5'r, so I don't want to do any other project untill RC5 is dead and gone. The top one will force the client not to flush if it can't find the keyserver or pproxy you have set it to use. Very handy if you are flushing to a pproxy and it happens to go down or has a network outage.
