Edit: I got it fixed. The problem was in the "Interfaces to watch" configuration option - I had left it blank, and it needed to have at least an asterisk (*) for the client to detect a network interface.
See new question in post below...
Today, I installed the distributed.net client to run RC5-72 for the first time on my 766MHz Celeron "work" computer with Windows 2000 Pro (doing sound recording and powerpoint for a church). It runs almost all the time (unless the janitor or someone else who thinks they know better shuts it down), but only has a dialup connection once a week (when I bring one up manually, each Sunday afternoon). For that reason, I thought that RC5-72 would make the best project for this system, since it has the ability to cache units for periods of offline-ness. And yes, I do have permission to install software on this system, so that's not a problem.
Anyway, the client installed fine (I downloaded the latest - as of this morning - zipped client from distributed.net). I set it up to use my email address, to only work on RC5-72, to queue enough units for 168 hours, and to run in dial up detection mode where it will automatically send if a connection is available; I did not mess with the network interfaces part, assuming that was best left at its default settings. When I run the client, it says it is not able to find a network interface (that might not be the exact message, but it is something like that; the error message was displayed even when a connection was up), and proceeds to work on a random unit. When I go back tonight, I should be able to post the exact error message. Until then, is there any advice you can give me to try to get this thing crunching away for Team AnandTech?
